Just ran another dyno with the viper CAI, and this time had a fan on the intercooler. I'll post the graphs when I get them but here are the numbers and some observations:
* Best run was 188.5HP / 234.7 TQ
* ran 2 3rd gear pulls then a 4th gear pull with less then 1min break between runs and car wasnt shut down. The runs got progressively worse which is a pretty good indication there is heat soak. the 4th gear pull was only 173.1HP / 227.2 TQ which is a bit of a drop from the best run.
* The air:fuel dropped right off the chart in 4th gear (leaned out bigtime) after 5500 RPM. I hope this is what Upsolute is going to work on with their new programming. The best run's air:fuel didnt drop that much, only dropped to 11 at 6000 RPM. (was 12-13 around 5500 and 13 at 5000
* there was a little less airflow then driving on the highway and logging. I think this shows that dynos arent a good way to measure the performance of a CAI such as the viper. I had a small fan blowing on the intake but don't think it helped much.
All in all I was quite happy. I see that the dyno is probably not a good reflection of what is happening while driving as heaksoak and more air due to the intake are hard to reproduce on a dyno.
Graphs to follow
Graphs to follow
