1 - 1 of 1 Posts
Feed your MK6 K03/IHI/K04 turbo with a supply of cold air with our new direct-fit high velocity intake kit.
This intake features a generously-sized inlet pipe that connects to the OE MAF sensor. The intake then receives high-velocity air fed directly from a 5" bellmouth.
This bellmouth is neatly housed in a heat shield that seals to the hood creating a thermal barrier from engine heat and allows only cool air to flow from the front of the vehicle.
This air intake kit provides all the necessary piping and couplers to plumb the intake system from the turbo to the MAF and then to the heat shield. The heat shield installs using the OE grommets for easy maintenance and reliable mounting with no rubbing or interference with other factory parts.
LEADING FEATURES:
  • INCREASED HORSEPOWER & TORQUE
  • ENHANCED ENGINE, TURBO, & BLOW-OFF SOUND
  • HIGH-FLOW BELLMOUTH
  • MASSIVE OVER-SIZED AIR FILTER
  • BLACK POWDER COAT FINISH
  • EASY INSTALL
  • USES FACTORY MOUNTING GROMMETS & HARDWARE
  • HEAT SHIELDING & DIRECTED AIR FLOW
  • REINFORCED SILICONE HOSES
  • FITS DSG AND MANUAL TRANSMISSIONS
LEAR MORE HERE
Video Overview:
Bellmouth CFD results
IE CAI vs. Competition CAI
1 - 1 of 1 Posts
