Since there are a lot of new 16v turbo projects being built/rebuilt and some new parts coming out it's time for another ultimate 16vt info thread (archived?). The point of this thread is to compare setups and offer advice / information.
Chassis: mk2 gti
Block: stock 9A
Pistons: J&E 8.5:1
Rods: integrated engineering 16v
Head: 9A (mild port + polish)
Head gasket: steel ABA w/ arp headstuds
Cams: autotech euro intake
Valves: stock w/ supertech springs, Ti retainers
Intake manifold: eurospeed? (square box
with nice stacks inside)
Throttle body: obd1 vr
Intercooler: 2.5" in/out REAL thick
Plumbing: 2.5"
Bov / dv: synapse
Exhaust manifold: racecraft log
Turbocharger: garrett t3/t4 50trim 0.48 ex. (looking for 0.63)
Wastegate: Tial 38mm
Downpipe: 3"
Exhaust: 3" straight
Management: digi 1 w/ SNS chip
Injectors: 630cc siemens
Spark plugs: NGK BKR7E .025" gap
Flywheel: autotech steel 10lb.
Clutch: Spec stg.3
Transmission: ATA 02A (stripped 3rd, going with mk4 vr gears)
Differential: Peloquin lsd
Shifter: stock g60 corrado
Everything else assumed stock.
No dyno before trans broke (3rd gear), went 12.9@115 on 17psi couldn't boost until 3rd gear without spinning and going nowhere (195 tires and .48 hotside).
Idles sometimes, currently has no o2 sensor. Wideband gauge between 12.7 and 11.5 under boost.
Looking to go standalone, 35R or 3076, cams in the future.
Chassis: mk2 gti
Block: stock 9A
Pistons: J&E 8.5:1
Plumbing: 2.5"
Bov / dv: synapse
Downpipe: 3"
Clutch: Spec stg.3
