We're pleased to announce the availability of our new Upgraded Audi I5 10V/20V Turbo Replacement External Wastegate Diaphragm - 035145797B! :thumbup:
Retail: $95.00 + Shipping
034Motorsport has released an Upgraded External Wastegate Diaphragm for Early Audi I5 10V/20V Turbo Engines, including the MC, 3B, AAN, ABY, and ADU.
We carried the factory replacement diaphragm for 10 years before Audi decided to discontinue it. In that time, our engineers had the opportunity to develop and test a stronger, more durable replacement.
The result is this polyester reinforced, high-temperature silicone diaphragm, which is over 50% thicker than the factory unit and capable of performing in high-temperature, high-boost applications.
Features:
- 2mm Thick High-Temperature Silicone Construction - Over 50% Thicker Than Stock!
- Polyester Fiber Reinforced Diaphragm - Same Construction as OEM
- Direct Drop-In Replacement
- Ideal for High-Temperature, High-Boost Applications
- Replaces Factory Part Number 035145797B
- C4 Audi UrS4/UrS6 - AAN
- Audi UrQuattro
- C3 Audi 100/200 - I5 Turbo
- B3/B4 Audi S2/RS2 -3B/ABY/ADU
Click Here to Order!
You May Also Be Interested In:
Audi I5 Wastegate Spring Upgrade - 1.9 Bar
