This is quoted from what a local VW tech got from VWoA:
If it's already been posted and I missed it - I'm a dumba$$ so ignore.
Quote » |
As of April 15, 2003, VW has a new Tech Bulletin out concerning ECU/ECMs (engine control unit/engine control modules). There has been a chronic problem with cold start misfires on the 1.8Ts, regardless of engine code. After several tests, it has been determined that the ECU/ECM needs to be flashed and a new program (fuel map) applied. On this particular TSB (technical service bulletin) it specifically states, and I quote "CAUTION! The following "Update - programming" (flashing) process may overwrite any "Tuned" ECM or TCM programming. A "Tuned" ECM or TCM is described as any ECM or TCM altered so as to perform outside the normal parameters and specifications approved by Volkswagen Of America, INC. If a particular ECM/ECU has been found to be "tuned", that owner is to be notified IN WRITING that the vehicle was found to have been tuned, and that any damage caused by the tuning of the ECM or TCM (including any adverse emissions consequences) will not be covered by Volkswagen Of America, INC. warranties. For any repair requested by the owner under warranty or outside warranty that requires flashing, which will automatically wipe out the "Tuning" program, your Dealership should advise the owner of the above and get his/her written consent (see attached ECM/TCM Tuning form) {I dont have that form with me, nor have I seen it yet} to the flashing procedure. |
