1 - 20 of 55 Posts
Hi,
I've noticed you people talk about this Vag-Com thing. I understand that it's some type of computer software, but I'm not entirely sure.
OK, so I own a VW Golf MK5 GTI. Now I need to know...
1) Is Vag-Com diagnostic software for vehicles?
2) Does Vag-Com allow me to modify the settings of my car?
3) Which is the official Vag-Com website?
4) If I use Vag-Com on my car, does it void any motorplan warranties?
5) I'm aware that there are different package versions of Vag-Com, which is best suited for my car?
6) Do I need to purchase any 3rd-party equipment, like cables or wires - or does Vag-Com come with everything I need?
7) For those of you that have Vag-Com, has it disturbed the behaviour of your cars in any way?
8) For those of you that have Vag-Com, is it worth it?
Thanks for your time, fellas!!
Chris - South Africa.
Modified by Inflicted at 11:23 AM 1-8-2006
Modified by Inflicted at 11:25 AM 1-8-2006
Re: Newbie Vag-Com Questions... (Inflicted)
VAG VOM is diagnosic software for Audi and VW (Skoda and Seat also).
Yes.
Ross Tech's Website.
VAG COM is not a chip; it doesn't "stay" in your car. It is simply an interface system to access, diagnose and customize settings on your car, among other things. There is no way to void the warranty per se, but you could potentially do some damage to your car if you don't know what you're doing.
MkV cars need either HEX-USB+CAN or HEX-COM+CAN cable depending on the type of computer you have (serial or USB ports).
You need to purchase the cable/interface from Ross Tech to unlock the software which is downloaded from their website at no charge.
Every change made through VAG COM should be carefully planned and executed. There are no "hidden" effects to making changes or diagnosing your car through VAG COM unless you somehow make a mistake that cannot be corrected. Every change should be carefuly made, planned and recorded so you can reverse it if you make a mistake.
Totally. http://****************.com/smile/emthup.gif
Also, I realize that it sounds easier to post your questions for someone to answer but all of them could have been answered by searching the forum.
Please also read Ross Tech's FAQ if you're considering the investment: http://www.ross-tech.com/vag-com/vag-com-faq.html
Good luck! http://****************.com/smile/emthup.gif
Modified by svander at 2:18 AM 1-8-2006
Banned
Tesla Cat Nose
Re: (Inflicted)
well worth it!
Well thought out post svander http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
VAG-COM should be the first upgrade to any MKV purchase.
(even before Wheels and Tint)
Re: (revtune)
Quote, originally posted by revtune »
Yes, you have helped more than one person with this post. I learned an incredible amount. Thanks!
x2
Re: Newbie Vag-Com Questions... (Tim Birney)
Quote, originally posted by Tim Birney »
even a drop?
thanks for the help svander
just understanding: vagcom accesses fuel maps/timing/air fuel ratios/ignition/fuel pressure etc.
so it is basically an access point to your ecu??
dont flame me, only 16 and only our messenger.
Re: Newbie Vag-Com Questions... (UTRIED)
Quote, originally posted by UTRIED »
VagCom does not acces the ECU. The ECU parameters are burned into a chip, and cannot be modified using VagCom.
VAG-COM allows you to scan the entire vehicle for faults, and gives you easy to understand definitions of the faults.
It allows you to modify different things on your car.
It allows you to graph particular functions of your car, as it is operating.
Visit:
and browse around.
a friend of mine has the vag com for his mkiv. will his cable totally not work at all for anything on the mkv? i just need to re-code the turn signal deal when i put the euro bulb holders in.
Re: (GearSlammer)
Quote, originally posted by GearSlammer »
The VAG-COM Cable for the MKV is the HEX+CAN cable. The MKIV cable is most likely just the HEX, so it will not operate on your Can-Bus equipped MKV.
Re: (D.Passat00)
can the vagcom change a setting so that when i put my car in reverse the side mirrors angle down?
i also need to use vagcom so the windows can get put down with the remote, right?
any other really cool stuff any of you guys have done?
1 - 20 of 55 Posts
