The PowerGasket for my car arrived in the mail today. I didn't want to wait for the weekend to install it and all the write-ups I saw said the install only takes about an hour.
For those of you that have no idea what a PowerGasket is for, click here.
I decided to get one for the insulation properties of the gasket, rather than any quoted performance gains. I've been logging a bit of data with VAG-COM (surprise, surprise) and it always worries me how high the inlet manifold temps get. Even when I drive the car sedately (ie: no WOT and shifting by 4000rpm), I regularly see the temps over 50 deg C (and even over 60 deg C) in summer. The deciding factor for me was how I can barely touch the inlet manifold after the car has been left sitting for about 30mins.
The tools used were a 5mm and 6mm allen head, 10mm socket, 10mm spanner, flat blad screwdriver, phillips head screw driver, rachet drive and varous extensions. Some carb cleaner is useful for cleaning off the old gasket from the head and inlet manifold.
The install was interesting as I had to remove the fuel injector rail. This worried me at first but it turned out to be really easy. I'm not going to do a complete step by step write-up as it would be different if your car didn't have an AEB motor (Kos is the only other Passat like mine and he's already got one on his car).
For those of you that are interested, here are some good write-ups that other people have written:
VW Passat
Audi TT
VW Passat
Audi TT
