95% tow over 10,000 lbs.!?!? Not from my world view. Just a bunch guys and gals with inferiority complexes rolling into Starbucks in something they have no business driving.
You make a valid point, but I believe the subject is WORK trucks. In the case of Ford, that would be the Superduty line, which in this context would be the F250 SRW through the F550 DRW. The F650 gets into the Medium truck class.
Also, we should talk about trailer weight classifications for commercial use.
A 10,000lb GVWR trailer is popular because you can use a vehicle up to 26,000lbs GVWR and tow up to a 10,000lb GVWR trailer, without needing to have a CDL.
At either 26,001 or 10,001 GVWR for truck or trailer, you then need to have a Class A CDL to use them for commercial operations.
The next size up is typically 14,000lbs GVWR, because it was possible to get a useful combination that was still
UNDER 26,0001 CGVWR.
For instance, I used to have a SRW 2011 HD3500 Silverado with an 11,400lb GVWR, and I had a gooseneck deckover tilt-bed built for it that I had tagged at 14,500lbs GVWR. We could haul around a 12,000lb piece of equipment with that, and the driver didn't need to have a CDL.
The way that worked was that I had 8,000lb axles installed. With a 12,000lb load, the Gross Weight came to 18,000lbs, but the trailer off-loaded 4,000lbs to the truck, meaning the 16,000lbs of axles were carrying 14,000lbs, or about 0.875% of capacity.
That used to be more important than it is now, because it used to be realistic to buy a 4wd 1-Ton that had a GVWR under 13,000lbs. Not so much anymore.
When I needed to replace the Chevy, I went with an F-550.
Side note: I would not buy a diesel engine work truck unless I was pulling at least a 14,000lb GVWR trailer; and if I was pulling something that size or larger, I wouldn't buy anything BUT a diesel engine. (
Talking full-size PS/DM/Cummins)
The point is, when you're talking about a real work truck, EV's just aren't practical. Yet.
They will be, and pretty soon, at least in terms of capabilities. Charging will still be an issue.
Without a Level 3 or Level 4 Charger, the battery capacities necessary become impractical for Level 2 or Level 1 charging.
