1 - 3 of 3 Posts
Well as of right now I have 1,000mi's on the Lysholm. Still running the 66mm pulley roughly 11lbs. I have the following mods to date: ISV re-route/944FPR/Custom downpipe w/Flowmaster mid muffler and Brospeed rear/ Metal intercooler tubes/Samco hoses/Low temp T-stat and Fan switch/Stage III chip that runs slightly rich/ported Throttle body/Crossdrilled rotors/Koni adj yellows with neuspeed race/frnt and rear upper bars/new bushings all the way around.
I would like to go with the 15lbs+ pulley 57mm...just guessing on size, mabye a 260 cam nothing to radical. I guess the last question would be fueling...injectors different chip. Any suggestions would be great. As it is now the car is very strong with barely 100,000mi's 92 G60 Toby
[Modified by vwg60saabturbo, 9:05 PM 4-9-2002]
Re: Next mods??? Suggestions (vwg60saabturbo)
i would go with a bigger cam...260 or 260/268 are the common ones i believe.
everyone says that you don't need bigger injectors unless you are at mega boost ie. 20lbs+
you can always opt for a new IC...FM or AtW
other than that i would keep some money in the bank for when something goes wrong...and maybe do some suspension work if you haven't done that already...
Re: Next mods??? Suggestions (Tom - G - ride)
the 260 cam as opposed to the 260/268, I was told would not cause interference. What do I know??? something about the valves and the lift....I don't know. I want to keep it safe even though I only drive the car a few miles a month if that.
[Modified by vwg60saabturbo, 9:09 PM 4-9-2002]
1 - 3 of 3 Posts
