This is the story of one VW-loving man's quest to find the perfect NGK standard copper (nickel-alloy!) spark plug for our beloved 2.5L inline-5 cylinder engine...read on friends!
So the only recommended COPPER spark plug (aka standard aka NOT platinum or iridium tipped AKA nickel-alloy outer electrode...remember all spark plugs have copper cores so it's kind of a misnomer!) for our 2.5L inline-5's is a Denso plug, K16GPR-U11, which I have not been very impressed with after 2 sets of 30k and 20k miles. Don't get me wrong, they were decent especially for the money ($3.07 per plug), but meh...
The alternative? Just buy OEM 2.5L plugs and be done with it you say? :screwy: No way, what am I made of money?! $12/plug is absurd, and Platinum tipped never seems to run as good (and that is backed up by electrical science...go look up conductivity of metals).
And since I've never had a poorly performing NGK plug in any application ever....the obvious next step was to spec out the Denso K16GPR-U11 plug, crossreference to NGK and BOOM, sexy electrical magic! :heart:
I came down to 3 NGK plugs that matched the Denso's specs (and as a check, they are all in the base family of the OEM platinum plug, PZFR5Q-11, hooray! :thumbup
ZFR5D-11, ZFR5E-11, and ZFR5J-11
So these are all the same-spec'd plug, with the variable letter denoting "special firing-end design" which of course NGK does not explain anywhere. Initially I was set on the "J" version, thinking that since the original OEM platinum plug was a "J" plug (PZFR5J-11), however I found some info indicating the "J" copper plug had a shorter insulator than the other coppers and the OEM platinum plug.
With that said, I chose the ZFR5E-11.
No real reason over the "D" version...I thought I saw that the "D" was a non-V groove electrode so that was my reason against it...wouldn't hesitate to try the "D" or the "J" though, but as always your miles may vary/do at your own risk yadda yadda...I can only comment on the ZFR5E-11 ...
... and let me say...THEY ARE AWESOME. Now of course these are not "official" OEM spark plugs for our engine, so just remember that...but the results speak for themselves. I'll say it again for effect...
THE NGK ZFR5E-11 STANDARD COPPER SPARK PLUGS RUN GREAT IN VW 2.5L INLINE-5 CYLINDER ENGINES !!!!!!!
Just had to gap down to .040"/1.0mm. The butt-dyno says YES, idle is smoother, MPG's are up (couldn't get more than 28 highway before, recorded multiple highway cruises on the NGKs at 72-75mph in the 30.X range!), and, oh yeah, did I mention they cost $2.50 per plug? The wallet also says YES.
So run along now to your local auto parts store, where they are literally ALWAYS in stock (part #4435) and rejoice at the thought of walking out with 5 quality NGK copper plugs for less than $13. Boom shakalaka. Y'all are welcome!
eace:
