check out our facebook page for more info on this car and what we do. i'll add build pictures over the last year that this took soon!
https://www.facebook.com/Nothing-Leaves-Stock-186423318042016/
A few quick pictures of this 2001 TT that we did a full 2013 2.5 TTRS swap into. Motor is full built by Iroz motorsports. Custom software and coding with haldex flash from United motorsports and lots of custom fab work done in house! On its way down to the tail of the dragon this weekend!
quick run down
-2013 TTRS motor full forge bottom end built by hank at Iroz
-mated to a modified O2M 6speed tans with custom falcon clutch
-custom cooling system to look and act like a OEM TTRS
-custom front mount intercooler, custom air box to feel oem look but with open air filter inside
-custom 5'' to 3'' vbanded downpipe, cat pipe. 3" catback
-TTRS throttle pedal
-oem TTRS ecu programmed and coded by United motorsports
-custom wiring to mate the TTRS ecu can-bus to K-line mk1 TT body harness
-custom tach converter
-custom electric power steering system
-KW V3 coilovers
-P3 gauge pod
-all oem inside, dash looks ad acts as oem mk1
-rear seat delete, carpeted and strut bar
-alcon front brakes
...and lots of hours and figuring out things!
-still needs the battery and side covers to be matched to wrinkle and he has a set of LM's to fit as well
contact us if you have any needs from inspections, tune, oil changes or crazy off the wall ideas...like this! we can make it happen!
www.nothingleavesstock.com
quick run down
-KW V3 coilovers
-P3 gauge pod
-alcon front brakes
