Alright, So I have spent a day and a half trying to get this previously problem free car to run. The car is an early 99 gti vr6 drivers edition. I even have a certified vw mechanic stumped. It seems like we have gone through everything!
Symptoms:
-NO crank, no power to almost everything (no lights, locks, stereo, windows, mirrors, etc.)
- Fuel guage works when key is in and the clock and odometer always work
- I hear the aux waterpump constantly working.
- All dash light indicators come on when the key is turned, minus the check engine light!?
- Keyless alarm module clicks when the key is removed from the ignition. The alarm light next to the driverside occasionally blinks when I engage the alarm with the key. (it is hit or miss)
-Battery replaced
-Boosted, still no change
What has been done:
-Ignition switch was replaced
-Alarm module was bypassed and the car cranked fine but the power to the fuel pump is not working so no start.
-door jam wires were checked and nothing is broken
- All fuses and relays were checked and swapped with those from a fully functional VR, still no change.
- All the grounds under the battery tray were cleaned as were the battery terminals.
- Starter has been ruled out as is cranks without problem when the alarm is bypassed
-The ecu was taken out and inspected and the alarm module still clicked with the ecu removed so I have also ruled a bad ecu out.
The thing is, the car just had a full rebuild and the engine bay is spotless, no visible bad grounds or corroded grounds.
The electrical worked without a flaw since the rebuild 3 months ago so I am left scratching my head.
I also want to know if the alarm module could still be the culprit even though it was bypassed and the problems still remained.
Help? I am taking any ideas.
Thanks folks.
Symptoms:
-Battery replaced
What has been done:
Thanks folks.
