Hi guys!
I have passat b6 2006 BMR. I bought it 6 months ago. My glow plug light used to work (at least I have seen it once for sure). According to VCDS glow plugs start for 2s. But no light on instrument cluster. I have changed Glow plug control module but still no luck. When doing an autoscan with VCDS no trouble codes are present for glow plugs or other things. Checked the fuses as well and all is good. Any ideas? I am thinking about burned LED on cluster itself. Also under 8 degrees C the car starts a bit strange (only 1st start in the morning). I am almost sure that glow plugs should work longer than 2 sec when its -1 Celsium...
