1 - 6 of 6 Posts
Re: no heat (slccorradoitaliano)
Do you have a bubble in the coolant somewhere. Have you tried a total flush and fill. That happened on my GTi when I replaced the radiator, did a flush and fill and all was well.
Good luck, heat is good!!!
Discussion Starter · #4 ·
Re: no heat (SLC_Demon)
well, it started after i replaced the head gasket...cars runs great, but we also replaced motor pump.....the one that pumps coolant.....i used the pump from a mercedes benz, its exactly the same pump all that needs to be done is the plug......anyways, the pipe that carries the coolant into the car is a bit limp
.....the pump is working because you can here it spin???? i have no heat at all and i cant figure it out? any help is appr. also, i got my rad cleaned when i did the gasket......do you think it might be a air bubble? thanks for the help http://****************.com/smile/emthup.gif
Re: no heat (mecca666)
i dont know what to say---- but my ac doesnt work, it just blows air but its not cold.... i tried recharging it but its still not cold. could there be a clog in the lines or sumpin?
1 - 6 of 6 Posts
