The amp is on and all the connections to the amp are fine but there is no sound from the speakers. It is an amp with two lit-up meters, normally the meters are fluctuating with the music but they are pinned to 0. I thought it might be the signal wire coming from the head unit, but the other amp, the one for the subwoofer, is on and the subwoofer is working. The signal wire is shared among the two amps as are the RCA outputs through a crossover because the radio only has one pre-amp out.
Any help with this. It sucks having no radio
Thanks
Thanks
