i just took the engine out ECU and wiring harness out of a 1990 corrado G60 and stuffed it under the hood of an 86 golf. i drove both cars to my house before dismantling them and they both ran fine. now that i have the G60 setup wired into the CE1 wiring harness i get no spark. i followed the diagram below that i found on here to wire everything in.
i have a yellow wire on the positive side of the coil that is part of the CIS system. from what i grap of it thats the 12v switched power. and i have the green wire from pin 25 on the digifant ECU harness hooked to the negative side of the coil. it sounds right to me but this is the first time attempting a swap like this. any input anyone????
Modified by VWracerG60 at 6:55 AM 6-15-2006
