Re: No start after driving for a while - won't even turn over (Icantdrive65)
Quote, originally posted by Icantdrive65 » |
The solenoid is mounted piggyback on the starter, so it is as new as the starter.
The dash lights do come on. Everything functions like normal except that it doesn't crank sometimes. The lights don't dim when I turn the key. I am going to go attempt to pick it up this morning while it is still cool (it's stuck at work). |
The bold section seems to be key (heheh). The lights don't dim and the starter doesn't crank. So that means power is not reaching the starter -- there's an open circuit. This means from the ignition switch to the starter, and all wiring and relays that are involved in the starting circuit, are involved.
Let the car sit over night. In the early morning (before the sun heats things up) see if the car will start. It should, right? Let's say it does. Turn the car off; don't let things warm up, we just want to make sure the car starts. Okay, now get a heat gun or, better yet, a hair drier and heat up the ignition switch. Leave the car door open but get the switch toasty (but don't melt anything!!!!). When it's hot, try starting the car. If it doesn't start, I'd bet it needs replacing. If it does start, we move on...
Now aim your hair drier at the fuse/relay panel. Concentrate air flow at the #12 relay (fuel pump relay) but heat up the row of relays as well. You can close the car door if you want so you are heating up the cabin as well. They should be warm to the touch and not super hot, we just wanna take the chill of 'em so room temperature or so is good. Now try to start the car. If it doesn't start, you may need a new fuel pump relay or there is some damage in the fuse/relay panel...that could be tricky to track down and fix. If it does start, hmmm...maybe the problem then lies within the engine compartment.
Engine still starting? Remember, don't let it get to operating temp, we just wanna see if it successfully starts. Yes? Okay, take the hair drier to the starter and get that starter hot! Don't melt the wiring or get it glowing red, just pretty damn uncomfortable for a finger to rest on. Try starting the car again! If it doesn't start, you got a bump starter/solenoid (it can happen). If it does start, crap, I don't wanna know cuz I'm running out of ideas
Report back on your findings and any other things you try. And remember, ONE THING AT A TIME! If you change two or more things you won't know which one actually was the fix!
