NOISE FROM OIL PAN, disaster? please help i'm petrified
591 Views 12 Replies 9 Participants Last post by  RedFuFuG60
13
tonight before coming home from work, finaly finishing my bilstein switch over, I started the car and I noticed a grinding, crushing, knocking noise coming from the car, so first thing I did is check the G-lader, but nothin'g, eventualy everything driven by the surpantine belt until I got to the crank pulley, and the loudest I can hear it is from the oil pan, and behind the crank pulley.
What the F#######uck is happening
I feel like shooting someone right now, cause my only assumption is rods, bent crank, loose crank bolt, or crank bearings, and the last two are the ones I can deal with, but the first two make me want to torch the car.
does anyone have any insight on this, or have had a similar experience, please I beg you help me
See less See more
1 - 13 of 13 Posts
Re: NOISE FROM OIL PAN, disaster? please help i'm petrified (RedFuFuG60)
I forgot to mention, I have to get this figured out by morning, so anything you guys got right now, throw it at me.
from the oilpan? wtf? i hope you ain't running the car.
my guess is the oil pump, i believe that gizmo is in the oil pan iteself. don't ****t your pants man, heh. things could be worse, your glader could have gone kaboom...
then that would suck
-danny
See less See more
6
Re: NOISE FROM OIL PAN, disaster? please help i'm petrified (CageyBee)
its ok
he has a ROTREX just incase
See less See more
lol, I left the car exactly where it was after I heard that noise, and if it is somethin' broken in the motor, I wish that it was the g-lader instead, I have 2 extra ones at home
Drain the oil and drop the pan. Nothing beats a visual inspection. http://****************.com/smile/emthup.gif
See less See more
HAH AHAHA HAAHAHAHAHAHAHAHAHAHHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
THANK GOD, it was the water pump, i just came back from the part store with a new thermostat and plastic housing thingy around it, new water pump, and the special coolant for dubs, aaaaaaaalllllllll for $60, my car's getting fixed tonight
If you didn't have the "special coolant" fluid in there before. THROUGHLY flush the old stuff out first before refilling. Do not mix the two!!! BTW I'm happy for you, that must be a load off your back. http://****************.com/smile/emthup.gif
See less See more
Re: NOISE FROM OIL PAN, disaster? please help i'm petrified (Scorrado)
whats the special coolant, and how do I tell if I have it already or not?
Re: NOISE FROM OIL PAN, disaster? please help i'm petrified (SMOKE2000)
special coolant is either blue or pink...pink is more special
Re: NOISE FROM OIL PAN, disaster? please help i'm petrified (BLUE NRG)
my coolant is yellowish-neon green????
3
Your wallet owes you one...
See less See more
2
hey the coolant they gave me was just green, and it was a VW only part store.
after fixing the problem with the water pump, which went fine, I took the car on a nice test drive and found out that I got 3 or 4 more lbs of boost since the old water pump was adding preasure to the belt, then came back to the shop to find my hood smoking, and when I popped it, fuel was spraying everywhere, so I went bazzziiiiirkooooooooo grabbed a water hose as fast as I can and sprayed the hell out of my fpr and fuel hoses. I checked it and one of the fpr brackets had broken so the fpr came loose and fluel was spraying out. Jesus christ, I pooped in my pants and now I know exactly how blackie felt about his car.
I'm still scared, I took a huge fire extinguisher and sat it in the passenger seat http://****************.com/smile/emthup.gif
After all this I don't think it's over, my fuel pumps feels like it's going out, when I let the car sit (loses inline fuel pressure) it's tough to start, but after starting it if I shut it off and start it again it works fine. The mechanic that works for us said that the fuel pump does that. sooooooo
See less See more
1 - 13 of 13 Posts
