1 - 5 of 5 Posts
like the topic states. Can this be done and how would you go about doing it, manually or with VAG COM. any input would be greatly appreciated.
Re: non DBW throttle valve calibration? AEB code engine (Spooled20v)
If your talking about a TBA, its group 060 in basic settings.
Re: non DBW throttle valve calibration? AEB code engine (Veedubgti)
Quote, originally posted by Veedubgti »
Thanks I'll look into it. My problem right now is that I have to open the throttle to get the engine to idle at all and when I crack the throttle up to 30 percent, it shuts down the timing and drops back to idle like the TPS is way out of whack. The ECU is defaulting to full rich because it doesn't know what to do. I've replaced just about everything so I'm looking for any possibility right now.
whats up Dave/ thanks for letting me log the car. Hey I thought TBA was 098 at least that is what I use. ???
Re: non DBW throttle valve calibration? AEB code engine (DubGray1.8T)
Quote, originally posted by DubGray1.8T »
It is 098 for non-DBW, but I think 060 works, as well.
1 - 5 of 5 Posts
