1 - 2 of 2 Posts
Re: normal maintainance? (RussellB)
What have you had done already, and at what mileages?
As long as you keep on top of belts (every 100,000km, with new water pump also), plugs (50,000km), wires (same), filters (air: 16,000, fuel: 50,000-100,000), and oil changes (5,000-8,000), you should be ok.
Longer-interval items I'd consider would be a full coolant flush with G12, a transmission fluid change (for manual transaxle, of course. Autos should get changed much more, but I'm assuming you have a stick), and so on.
Otherwise, your engine should be solid with just the normal maintenance for another 150,000 kms easily.
1 - 2 of 2 Posts
