1 - 1 of 1 Posts
Discussion Starter #1
I replaced PCV, rear breather hose and also replaced DV (G) now! The other DV (C) was not even bad! Did some VAG logs and specified PSI is 21 and I am only getting 15 psi if I am lucky! I have 06 Passat with APR Stg2+ APR DP and also have APR HPFP!
Now I am getting Fault code:
1 Faults Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - MIL ON
Boost Log:
Could not go all the way to 6500 rpm's, but specified at redline is 10 psi and actual is 5 psi.
Modified by lour32 at 7:55 AM 7-1-2008
1 - 1 of 1 Posts
