I purchased an HPA FT-470 for my MK4 R32 which comes with their air to water intercooler setup. The heat exchanger is integrated with a short runner intake manifold. With this system, the intake and boost track is relatively short, going directly from the intake to the compressor then from the compressor to the intake manifold/heat exchanger and on to the combustion chamber.
I have been toying around with the idea of adding a water/meth setup to my car to augment the AWIC (for cooling) and for the possibility of being able to run higher boost on 93 octane. In my research, I have found that the best performance from these systems seems to come from a dual nozzle setup but everything I have read also suggests placing the high flow nozzle a significant distance away from the combustion chamber. These examples are always using a traditional air to air intercooler setup where there is a decent amount of pipe between the intercooler and the combustion chamber. With my setup, would the distance from just after the mass air flow sensor (bolted directly to the air filter) be a good enough distance away from the combustion chamber? What about the fact that the nozzle would be pre-turbo and pre electronic throttle body, is this distance far enough for the water to evaporate and not cause damage to the turbine and or throttle body? Or should I just forget it and go with a single nozzle setup?
I'm just learning about water/meth setups so sorry if I'm way off base here... Just let me know if I'm being a dumb a$$. Thanks.
