NS Rear Sway: Which setting is stiffer?
397 Views 5 Replies 5 Participants Last post by  rs4-380
If search worked I'd use it. http://****************.com/smile/emthup.gif
On the NS Adjustable rear sway, which of the three holes achieves the stiffest setting? The one closest to the bend in the sway (i.e. furthest from the end of the swaybar)?
See less See more
1 - 6 of 6 Posts
Re: NS Rear Sway: Which setting is stiffer? (CoolWhiteVR6)
front holes
Re: NS Rear Sway: Which setting is stiffer? (BoraBuck)
Front holes, that means the ones closest to the ends of the swaybar?
Re: NS Rear Sway: Which setting is stiffer? (EPilot)
Thanks EPilot http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
3
if you ever forget again just think about it this way. If you were holding on to both ends of the bar (one end in each hand) and wanted to bend one end up, and one end down (this is what a swaybar combats) would it be harder it you slid your hands to the back (ends) of the bar, or farther forward toward the bends?
think about it
See less See more
1 - 6 of 6 Posts
