Re: (bobpearson90278)
Quote, originally posted by bobpearson90278 » |
The width is around 7 1/2"s.
The offset I think is 6"s. |
Look for some numbers inside there. Something like " 15 x 6.5J ET 35" or something. Those are your wheel diameter x width (J for bead type) x offset, respectively. If you're measuring 7.5" total width, your actuall width (across the tire bead mounts) is 6.5". Regarding your '6" offset', it sounds like you're measuring the back spacing. If you actually have 6" back spacing, you're looking at something like ET 57. That much backspacing will give you trouble with clearance around the strut bodies/rear trailing arms/etc. You will have to use wheel spacers to get them far enough out to clear everything.
Have you put them on the hubs yet to see if they clear everything without spacers?
Based on my experience, if they are 7" wide at the bead, you will want to see something like 15 x 7J ET 25 for a good fit.
Modified by snowfox at 4:21 PM 11-28-2006
