O2 sensor wires....which color???
860 Views 6 Replies 4 Participants Last post by  turboit
okay, I have a Air/fuel gauge and need to intercept the sensor signal wire (of course) and the sensor ground wire on the oem 4-wire heated sensor.
BTW this is on a '95 2.0 8V
Thanks in advance
1 - 7 of 7 Posts
Re: O2 sensor wires....which color??? (turboit)
you want the black wire
Re: O2 sensor wires....which color??? (Gerapudo)
quote:[HR][/HR]you want the black wire[HR][/HR]​
so I'm assuming that's the ground? Which is the actual wire that sends the signal?
Thanks Gerapudo http://****************.com/smile/emthup.gif
See less See more
ok you want the wire that is all by its lonesome. There are 4 wires and 5 holes for wires on the plastic connector. There should be three then a space then a solo wire. You want the solo wire!
in my car, the black wire IS the signal wire.
Re: O2 sensor wires....which color??? (speed51133)
black is signal, but dont tap it on the sensor side of the connector, tap it on the ECU side.
See less See more
Re: O2 sensor wires....which color??? (XSiVE)
Thanks guys, really appreciate the help. http://****************.com/smile/emthup.gif
See less See more
1 - 7 of 7 Posts
