im in the process of installing an o2 simulator from casper electronics that sends a signal to the ecu suggesting that everything is allright with the cat. hence- no cel. i recieved one already, installed it, then boom-cel. the signal being sent was too high of a resistance according to the 1551 and the measuring value block. so caspers is sending out another one which will be in the range as described in the measured value block catolog. well see if this works-keep the fingers crossed and ill keep all interested informed. i know there are other companies have a sim in developement- then it will be a matter of seeing which one is cheaper- but lets see if this works first.
p.s. is anybody interested in what im doin?
