1 - 2 of 2 Posts
So I'm having problems getting my O2a CCM trans to shift into first and second, checked everything visually, bushings on the linkages are good and the shifter was replaced with a B&M not to long ago. What i see when i try and shift manually in the engine bay is that its hard to get into gear because the vertical shift tower seems to have a fair amount of play when it is near the bottom (first, second reverse) and the upper part of the tower seems to have lateral play, almost as if a bushing/bearing should go between the tower and cast part that bolts to the top of the trans in the picture. Anyone have an exploded diagram of the O2a shift tower?
1 - 2 of 2 Posts
