1 - 20 of 100 Posts
I'm posting this up so we can have a master list of OBDeleven coding. Like me, I have had an OBDeleven for quite a while but have only used credits to make the two changes I've made on my Golf R, Euro tail lights and soundakor. Other than that it seems foreign to me how to code to make changes, hence this thread to help those like myself and all the new '17 R members.
So, copy/paste, add, share all your OBDeleven tweaks here so we all can benefit and help members.
Subscribed. Just got mine for my birthday last week. So far I changed the comfort blinker from 3 to 5 and used credits to make my passenger mirror dip. I'm a bit confused about how to translate Ross-Tech VCDS instructions into OBDeleven instructions, but there are other things I'd like to try.
It's quite easy to translate from VCDS to OBDeleven. They both use the same structure and hierarchy of functions for the most part.
Window control from FOB
Window control from door
DRL only on Coming Home/Leaving Home
DRL on/off from settings
Full gauge Illumination on parking lights
Comfort blinkers to 4 blinks
Fan speed shown while in Auto
LED tail lights with rear fog
Soundaktor to 25% volume
That's what I've done so far using VCDS coding instructions on my OBDeleven.
Sent from my ONEPLUS A3000 using Tapatalk
2019 Arteon, 2016 .:R, 1991 Mazda B2600i
Generally I agree with you. I have had no trouble doing things described in VCDS using the OBDeleven.
But...
lemme know how you make out with the high beam assist. For me, this is where it breaks down.
Discussion Starter · #7 ·
Please recall, this thread is to be a end-all be-all for people using OBDeleven, so my intention is to have members dump a bunch of info in here from how to translate to step by step instructions for all the members here from old to new.
But...
Sigh. No HBA here because I have one of the early production MY17s without DAP.
You're right so let's get back to basics.
Generally, all the VCDS directions start with a control module followed by adaptations.
Once your the app syncs up with your car, you start by choosing a control module (central electrics, etc.). Then you chose adaptation from the resulting menu and find the particular adaptations required by the coding tweak you want to do.
The more you use it, the more things become clear.
  • Like
Reactions: Mikekyle
Display current DSG gear in the in MFD in both drive and sport mode.
Has anyone figured out how to accomplish this feature from the APR TCU upgrade? Gotta be coding...
"Gear Display Activated - Shows the current gear in the factory multi functional display in both drive and sport mode."
Been busy accumulating credits for VIM. Finally got 100+ at the rate of 5 free credits/day...
OBDeleven vehicle history log
App
Name: Enable fan level display when on auto
Old value: OFF
New value: ON
Mileage: 900 km
Date: 2016-10-24 09:29
App
Name: Windows function from remote
Old value: Select value:
New value: ON
Mileage: 900 km
Date: 2016-10-24 09:28
App
Old value: OFF
New value: ON
Mileage: 863 km
Date: 2016-10-14 11:24
App
Old value: 100%
New value: OFF
Mileage: 863 km
Date: 2016-10-14 11:23
App
Name: Discover engineering menu
Old value: OFF
New value: ON
Mileage: 855 km
Date: 2016-10-14 11:00
App
Name: Seat belt warning
Old value: USA
New value: OFF
Mileage: 855 km
App
Name: Open door alarm
Old value: Driver door
New value: OFF
Mileage: 855 km
Date: 2016-10-14 10:59
App
Name: Comfort turn signals
Old value: 3
New value: 5
Mileage: 855 km
Date: 2016-10-14 10:58
It's been discussed on the VCDS thread, consensus seems to be that it's part of the TCU firmware and you can't access it via OBD11/VCDS. Stands to reason, the only way to get it seems to be through one of the tuners TCU flashes.
I've only done the 'open exhaust valves'
what is mirror dip? do you have to buy an aftermarket mirror with motor?
Nope. It just makes your passenger mirror glass angle down when reversing so you can avoid curbing your wheels. No additional hardware necessary.
Lots of useful info here:
http://obdeleven.proboards.com/thread/167/coding-adaptations
If what you seek is not in that thread, the board has many topics which likely hold the answer: http://obdeleven.proboards.com/board/81/mk7
I've coded my DRLs to remain on 100% even with the HID headlamps on, and disabled the turn-signal wink.
Most recently, I've coded my new carbon-fiber power-folding mirrors, which are spectacular :)
What mirrors did you get?
Sent from my SAMSUNG-SM-G935A using Tapatalk
1 - 20 of 100 Posts
