1 - 9 of 9 Posts
First things first... no start...
Replaced IP harness to ECU
Replaced ECT sensor
Replaced IP
Replaced ECU
Scan, reset faults, comes back immediately.
Glowplug light will flash after about 30 seconds.
here's the complete scan...
Quote »
VAG-COM Version: Release 607.2-UD
Monday,16,October,2006,21:43:49
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Address 01: Engine
Part No: ROCKETCHIP
Component: s02c EDC G40A 1629
Coding: 00001
Shop #: WSC 00066
3 Faults Found:
01268 - Quantity Adjuster (N146)
35-00 - -
27-00 - Implausible Signal
00765 - Modulating Piston Movement Sensor (G149)
35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Part No: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
No fault code found.
Address 15: Airbags
Part No: 1J0 909 609
Component: C AIRBAG VW3 SG 0002
Coding: 00067
Shop #: WSC 01317
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
Part No: 1J0 919 951 A
Component: A4-KOMBIINSTR. VDO V01
Coding: 06242
Shop #: WSC 00000
Address 46: Central Conv.
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 01317
Part No: 1J1959801C
Component: 60 Tõrsteuerger. FS0002F
Part No: 1J1959802D
Component: 60 Tõrsteuerger. BF0002r
Part No: 1J4959811C
Component: 60 Tõrsteuerger. HL0002r
Part No: 1J4959812C
Component: 60 Tõrsteuerger. HR0002r
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
Address 56: Radio
Part No: 1J0 035 180 C
Component: RADIO 0002
Coding: 01401
Shop #: WSC 01317
End --------------------------------------------------------------------------------------------------
Any ideas
Quantity adjuster combined with piston movement sensor ordinarily means that for whatever reason, the ECU is either not communicating with the injection pump (multiple wiring connections have to be faulted in order to get both codes since the actuator and the position sensor are separate wires, although it's through one main plug at the ECU and one main plug at the injection pump) or the injection pump itself is fubar'ed inside.
Re: (GoFaster)
The IP harness has been replaced (it has the IP, Engine Speed, #3 injector, ECT, VSS, Oil temp (pressure???), and Glow plugs IIRC), as well as the ECU, and Injection Pump...
Is there anywhere that I can ohm, or check for voltage?
I think there is another ground in the plenum near the pollen filter.
There are some connections inside of the wire receway under the air filter, I get continuity from one side of the connector to the other, and they are still mirror like in appearance, so I don't think that's the problem.
After clearing the codes in Vag-Com, they come back the moment you click "OK"...
Re: (alphaseinor)
here is what the bentley cd says (minus the pics and formatting):
error code 00765:
Volkswagen > A4 Platform > 1999 - 2005
1.9 Liter 4-Cyl. 2V TDI Fuel Injection & Glow Plug, Engine Code(s): ALH m.y. 1999 - 2001
23 - Diesel Fuel InjectionModulating piston displacement sensor -G149- and Quantity adjuster -N146-, checking The quantity adjuster is an electro-magnetic swivelling positioner which is controlled by the ECM via a directed duty cycle (on-off ratio). The eccentric shaft on the quantity adjuster moves the modulating piston on the high pressure piston thereby regulating the quantity of fuel injected.
The Modulating piston displacement sensor -G149- informs the ECM of the position of the Quantity adjuster -N146- and then determines the amount injected.
Note:
Only gold-plated contacts must be used when repairing terminals in the connector to injection pump quantity adjuster.
Special tools and equipment
V.A.G 1551/1552 Scan tool with adapter cable V.A.G 1551/3
Test box VAG 1598/22 (through my 1999)
Test box VAG 1598/31 (from my 2000)
Digital multimeter US1119 (Fluke 83 or equivalent)
Adapter set VAG 1594
Wiring diagram
Conditions
Coolant temperature must be at least 85 ° C, => display group 01, display field 4.
Work sequence
Connect V.A.G 1551/1552 => page VW-A4-FU01-01-001-0601-14.
Run engine at idle speed and press buttons -0- and -1- to select "Engine electronics" address word 01.
Rapid data transfer HELP
Select function XX Indicated on display
Press buttons -0- and -8- to select "Read measured value block" function 08 and confirm entry with -Q- button.
Read measured value block HELP
Input display group number XXX Indicated on display
Press buttons -0-, -0- and -1- to select "Display group number 1" and confirm entry with -Q- button.
Read measured value block 1 →
840 rpm 6.5 mg/H 1.480 V 87.3 ° C Indicated on display
Check coolant temperature in display field 4
Specification: at least 85 ° C
Continue with check only when coolant temperature is attained.
Check voltage supply from modulating piston displacement sensor in display field 3.
Specification: 1.450 to 2.000 Volts
Press the → button.
Press buttons -0- and -6- to select "End output" function 06 and confirm entry with -Q- button.
Switch ignition off.
If specification is not obtained, check Modulating piston displacement sensor -G419- and quantity adjuster as described in following steps:
Checking Modulating Piston Displacement Sensor -G149-.
Disconnect 10-pin connector from Modulating piston displacement sensor -G149- (connector to injection pump quantity adjuster) (arrow).
Measure resistance between connector terminals 1 + 2 and 2 + 3.
Specification: 4.9 to 7.5 Ω
If the specification is not obtained:
Replace injection pump => page VW-A4-FU01-23-001-0723-19.
Check DTC memory and, if necessary, repair any malfunctions and then erase => page VW-A4-FU01-01-001-0801-22.
Read readiness code => page VW-A4-FU01-01-005-0201-91.
If the DTC memory has been erased or the engine control module was disconnected from permanent battery positive (B+), the readiness code must be generated again => page VW-A4-FU01-01-005-0301-93.
If the specification is obtained:
Remove wiper arms and plenum cover.
=> Repair Manual, Electrical Equipment, Repair Group 92
Connect test box VAG 1598/22 (through my 1999) or VAG 1598/31 (from my 2000) to control module wiring harness.
Check wiring between test box and connector for open circuit according to wiring diagram.
Test box socket no.
Terminal
Through MY 1999
From MY 2000
1
56
108
2
57
106
3
64
99
Wire resistance: max. 1.5 Ω
Check wires for short to one another, to vehicle Ground and to battery positive (B+).
Specification: ∞ Ω
If wiring and the resistance measurement values are OK:
Replace engine control module => page VW-A4-FU01-23-003-0223-106.
Checking Quantity Adjuster -N146-
Disconnect 10-pin connector from quantity adjuster (connector to injection pump) -arrow-.
Measure resistance between connector terminals 5 + 6.
Specification: 0.5 to 2.5 Ω
Test box socket no.
Terminal
Through MY 1999
From MY 2000
5
2
1
5
28
2
6
80
116
6
80
121
6
80
Specification: ∞ Ω
Re: Odd problem VAG-COM scans included (brianhague)
error 01268
Note:
Wiring diagram
Conditions
Work sequence
Press the → button.
Test box socket no.
Terminal
Through MY 1999
From MY 2000
1
56
108
2
57
106
3
64
99
Specification: ∞ Ω
Test box socket no.
Terminal
Through MY 1999
From MY 2000
5
2
1
5
28
2
6
80
116
6
80
121
6
80
Specification: ∞ Ω
Re: Odd problem VAG-COM scans included (Godlike)
and, 00532 with a signal too low.
hope some of that helps..
Heating & Air Conditioning
01 - On Board Diagnostic (OBD)Read Measuring Value Block (function 08) Notes:
During the function Read measuring value block, the Climatronic regulation is in operation.
8 display group numbers display up to 4 measuring values each.
To safely read measuring values while driving, an assistant is required.
Connect VAG 1551 Scan Tool (ST) and enter address word "08 AC/Heating electronics" and then press → button, until "Select function XX" is shown in display => page VW-A4-HA01-01-003-0201-8.
Select function XX Indicated on display (function selection):
Press buttons -0- and -8- to select function 08 Read measuring value block.
Rapid data transfer Q
08 - Read measuring value block Indicated on display:
Press -Q- button to confirm entry.
Enter display group number XXX Indicated on display:
Using the 1551 button pad, enter the required display group number (following example shows display group 001).
Read measuring value block Q
Enter display group number 001 Indicated on display:
Read measuring value block 1 →
1 2 3 4 Indicated on display:
Notes:
Interpreting measured values in individual display fields => tables beginning on page VW-A4-HA01-01-003-1001-45.
With the printer is switched on, the information on the display will be printed out.
After completing the Read measuring value block function, check DTC memory => page VW-A4-HA01-01-003-0301-12
If measured value specifications are met in all display fields:
Press → button.
Note:
To easily change between display groups, proceed as follows:
Display group
VAG 1551
VAG 1552
Higher
Press button 3
Press ↑ button
Lower
Press button 1
Press ↓ button
Skip
Press button C
Press button C
Table of selectable display group numbers
Display field
Designation
001
1
A/C clutch -N25- switch-off conditions (Codes 1 to 12)
Code 0: -N25- is not switched off
Code 1: -N25- switched off by A/C pressure switch -F129- due to excess refrigerant system pressure.
Code 2: -N25- switched off because of fresh air blower -V2- with control module for fresh air blower -J126- malfunction.
Code 3: -N25- switched off by A/C pressure switch -F129- due to insufficient refrigerant system pressure.
Continued on next page
Display field
Designation
Code 4: Not displayed.
Code: 5 -N25- switched off for 4 seconds (no malfunction). Code 5 is only displayed for 5 seconds. If continuous, check speed signal.
Code 6: -N25- switched off with ECON button (no malfunction).
Code 7: -N25- switched off because A/C system is switched off via button for fresh air blower speed (no malfunction).
Code 8: -N25- switched off because ambient temperature is below 3 ° C (37 ° F) (to prevent icing, no malfunction). Check temperature sensors -G17- and -G89-.
Display field
Designation
Code 9: Not displayed.
Code 10: -N25- switched off because voltage supply is below 9.5 V.
Code 11: -N25- switched off by "Hot" warning lamp via Climatronic control module -J255-.
Code 12: -N25- switched off by Automatic Transmission Control Module (TCM) or Engine Control Module (ECM) via Climatronic control module -J255-.
Display field
Designation
2
Engine speed recognized:
Code 0: no
Code 1: yes
3
Road speed
Display: 0 to 255 km/h
4
Standing time
Code 250: Battery was disconnected.
Codes 0 to 240: Time for "ignition off" in minutes.
Code 255: Transfer malfunction.
Display field
Designation
002
1
Temperature regulator flap motor -V68-
Measured value codes: 0 to 255.
(Permissible deviations from specifications ± 2)
2
Specification: 0 to 255
3
Flap position: air supply cooled.
Codes 0 to 149: -V68- malfunctioning.
Codes 150 to 250: -V68- OK, provided basic setting (function 04) was completed.
Codes 251 to 255: -V68- malfunctioning.
Display field
Designation
4
Flap position: air supply heated.
Codes 0 to 4: -V68- malfunctioning.
Codes 5 to 100: -V68- OK, provided basic setting (function 04) was completed.
Codes 101 to 255: -V68- malfunctioning.
003
1
Central air flap motor -V70-
2
Display field
Designation
3
Flap position: air flow to instrument panel vents.
Codes 0 to 149: -V70- malfunctioning.
Codes 150 to 250: -V70- OK, provided basic setting (function 04) was completed.
Codes 251 to 255: -V70- malfunctioning.
4
Flap position: air flow to footwell/defroster vents.
Codes 0 to 4: -V70- malfunctioning.
Codes 5 to 100: -V70- OK, provided basic setting (function 04) was completed.
Codes 101 to 255: -V70- malfunctioning.
Display field
Designation
004
1
Footwell/defroster flap motor -V85-
2
3
Flap position: air flow to footwell.
Codes 0 to 149: -V85- malfunctioning.
Codes 150 to 250: -V85- OK, provided basic setting (function 04) was completed.
Codes 251 to 255: -V85- malfunctioning.
Display field
Designation
4
Flap position: air flow to defroster vents.
Codes 0 to 4: -V85- malfunctioning.
Codes 5 to 100: -V85- OK, provided basic setting (function 04) was completed.
Codes 101 to 255: -V85- malfunctioning)
005
1
AIr flow flap motor -V71-
(Permissible deviation from specification ± 2)
2
Display field
Designation
3
Flap stop: fresh air flow to passenger compartment.
Codes 0 to 149: -V71- malfunctioning.
Codes 150 to 250: -V71- OK, provided basic setting (function 04) was completed.
Codes 251 to 255: -V71- malfunctioning.
4
Flap position: recirculating air flow in passenger compartment.
Codes 0 to 4: -V71- malfunctioning.
Codes 5 to 100: -V71- OK, provided basic setting (function 04) was completed.
Codes 101 to 255: -V71- malfunctioning.
Display field
Designation
006
1
Value calculated by Climatronic control module -J255- in ° C as displayed in A/C control head -E87-.
Value is calculated from temperature measurement at fresh air intake duct temperature sensor -G89- and outside air temperature sensor -G17-.
Value is less than measured value from -G17- and -G89- when the vehicle has just been parked.
A malfunction is not present if the measured values of temperature sensors -G17- and -G89- display actual values.
The values are almost equal when driving over a longer distance.
-G17- or -G89- are malfunctioning if the values are extremely abnormal.
Display field
Designation
2
Fresh air intake duct temperature sensor -G89-.
Actual measured value in ° C.
3
Outside air temperature sensor -G17-.
4
Sunlight photo sensor G107-.
Measured value in %, from 0 to 120.
007
1
Sender for outlet temperature, center -G191-.
2
Sender for outlet temperature, floor outlet -G192-.
3
Instrument panel interior temperature sensor -G56-.
4
Not applicable.
Display field
Designation
008
1
Fresh air blower -V2- with control module for fresh air blower -J126-.
(Specifications measured in V)
Blower off: 0 V
One blower speed display segment: 3.6V
Seven blower speed display segments: 12 V
2
Actual value measured in V.
(Permissible deviation from specification ± 0.8 V.)
3
Terminal 15
Actual measured value in V.
4
Voltage at A/C clutch -N25-.
1 - 9 of 9 Posts
