Doing my pressure tests like a good boy and the warm control pressure was 4.0 Bar.
Slightly on the high side for a Scirocco which should be between 3.4 to 3.8 bar warm.
My system pressure was 5.5 Bar which is ok but at the high end of the acceptable range.
I put in my old CPR and that read 3.95 Bar. Two bad / borderline CPRs?
My car is a bit off, runs very lean at higher RPM / load so I was thinking high CPR makes things lean
so that might be the root of the problem.
I just don't know how sensitive these things are ... is +0.2 Bar enough to throw things off majorly?
Good CPRs are rather expensive so I don't want to buy yet another one.
The Dizzy was supposably rebuilt.
Should I try to lower the system pressure a smidgen?
