1 - 4 of 4 Posts
I bought a car with a broken odometer. Meh, but I would like to know relative milage from when I got it for my own repairs and oil changes and the such.
Both the trip odo and the main ones are broken, is there anyway to fix these or do I need a new one?
Also is the light with the mpg and stuff like that supposed to light up? Mine dosent. Thanks.
you need to take the gauge cluster out to change the bulb - and you need to take the cluster apart - tedious but not really that hard - to fix the plastic gear that broke in half inside the odometer.
Re: ODO broke, fixes? (werksmini)
take it apart, you may find that the shaft with the red gear has slipped off on the last digit. I took the shaft out, re-aligned the digits and pushed it back into place. Note that you don't need to remove the clear plastic cage that houses the digits to do this, just take the face off and you'll see the gears/shafts.
1 - 4 of 4 Posts
