Status
Not open for further replies.
1 - 3 of 3 Posts
Have you been looking for an OEM alternative to an MP3/Blutooth capable aftermarket radio, but have found whats out there to be drastically overpriced for what you are getting, not to mention complicated to install? Well, STOP before you spend $1000+ on an aftermarket head unit, and then look no further than the OEM Accessory Radio RMT 300. This OEM head unit is the perfect and easiest upgrade in order to get bluetooth audio and phone installed into your car. You also have the option of connecting your phone, or MP3 device through a USB cable or 3.5mm Aux. Port. There is even a SD Multimedia card slot on the head unit to make sure, no matter what your tunes will always be with you!
One of the nicest parts about this head unit, it its overall look. With a very OEM style, it will blend seamlessly into your car. It will not like it was added, but more of that it was a factory part that ins originally installed in your car.
This head unit is not a difficult install and cal be done at home, or taken to a professional installer. Please make sure to select from the drop downs the necessary kits in order make make sure all the functions work properly.
Have any questions about compatibility with your car? - Feel free to email us at [email protected]
Interested in purchasing this head unit for your car? - BUY HERE!
1 - 3 of 3 Posts
Status
