Status
Not open for further replies.
1 - 3 of 3 Posts
OEM Audi TTRS 370mm Cross-Drilled Brake Rotors - @ HS Tuning
Audi Original Equipment direct from Audi Part # 8J0615301F for replacing the front Audi TTRS brake rotor. These are 370mm, two piece, cross-drilled pieces coated with the factory anti-corrosion coating for longevity and performance. Wether your OEM rotors warn out and need to be replaced, or your upgrading your car to these OEM big brake rotors, these are sure to impress.
We can also put together an OEM TTRS Big Brake Kit for those out there with A3/TT/MKV + VI Golf/GTI/R32/R This would be a full front conversion kit and include calipers, rotors pads, lines and all hardware needed. Priced at $2,799.00 (Contact [email protected] for more information)
Interested in Purchasing these Rotors? - BUY HERE! $219.99 (Buy a set and get $10 shipping)
hello this tt-rs rotors are direct fix on audi a3 09 fwd all stock and also if this fix u guys have the rear ones thanks
Hello,
Thank you for your message.
These are not a direct fit, you would need to get new calipers, pads and hardware. We have a kit of this priced at $2,799
Please let me know if you have any other questions.
Thanks!
1 - 3 of 3 Posts
Status
