Re: (TheGreasyJap)
Quote, originally posted by TheGreasyJap » |
The headlights work fine, it's the Phatbox that pauses. The wiring is all factory, the 12-10 pin adapter being made with factory parts. I'm thinking it's just the Phatbox and it's notorious sensitivity to anything electrical.... |
sorry, no experience with the phatbox!
but here are a few other things "electrical" to consider.
1) make sure that you don't run your signal lines too close to PWR/GND lines (that carry relatively high current) - this, in general, can create noise in your signal lines.
2) when an HID ballast initializes, it creates a spike on the PWR/GND lines for the ballast. This can be as much as 50A for a few micro seconds (of course not long enough to blow the fuse). This spike can cause issues on other lines running near these lines.
hope you get it figured out. http://****************.com/smile/emthup.gif
