Re: (timmyd)
yes, it's the same dark red you get in the r32 tails.
Quote, originally posted by linedpaper » |
yes, it's the same dark red you get in the r32 tails. |
Quote, originally posted by r32-1163 » |
Does anyone know if it's possible to do the install without having to run any additional wires? It won't blink amber without the wires right? but will the blinkers still work? Does anyone know of a really good DIY? The ones I've seen are "ok" but doesn't explain everything to a degree that I would be 100% confident doing the install. I really don't want to F*ck up on my Brand New R32! I saw someone selling ECS Tuning Harnesses for MKV Jetta Led installs, I was thinking to buy these and switch the pinouts to match what's required for the Golf/GTI/R32 LEDs. This way if I need to change back the tails, it's much more of a plug and play job. I got a VAG-COM to USB cable off ebay for cheap. Still worried about changing stuff on my New Car tho. I'm a Honda guy, only used to work on Acuras/Hondas, this is the first time I bought a European car. Picked up the oem Ipod kit, monster mats and trunk mat from 1stvwparts.com gonna put those in this weekend. |
same as the Golf/GTI/R32 here's a pic: ![]() Modified by r32-1163 at 4:00 PM 10-4-2007 |
do a search for harness it comes up in the Jetta GLI category, be warned tho, they are expensive 89 bucks well worth the cost of messing up my stock wiring if you ask me tho. |
Quote, originally posted by timmyd » |
I hear that, but I have seen what 5 years and a hacked wireing harness can do to a volkswagen. I would buy those if I bought the LEDs just to keep my harness 100% untouched. I just need to find a local vag com and I will be set |
Quote, originally posted by beanie338 » |
Quote, originally posted by nugj » |
Guys I never saw any follow ups indicating whether or not these harnesses form ECS Tuning actually could be used to make the pin conversions to install the OEM (or other) LED Taillights on the 08 R32 or not. Did they work? Did you still have to run extra wires back to the LED lights from the Euro switch in order to get them to work properly or did using these harnesses allow you to make the pin conversions without adding an extra wire on each side. I could not figure out from the postings if these harnesses were intended to make the pin conversions AND eliminate the need to run a fourth wire in order to prevent an error message that could not be cleared or if these were used WITH a fourth wire to make the pin conversions AND keep from instigating an error message that could not be cleared. Sorry for the rambling questions, Obviously these rear taillight conversions are more complicated than they look. Even asking a question about them gets complicated. Anyway I hate the idea of hacking into a harness and will do just about anything to make this job easier requiring less invasiveness with regard to the existing wiring. Any additional info from folks that have done this job and used these harnesses on the R32 would be much appreciated. |
Quote, originally posted by jimb » |
This is what I started with, but since I wanted both rings to light up as parking and brake lights I added a wire. Even when I had my car wired like yours, I still had a bulb-out error. I am curious as to what your long coding for bytes 9 throuh 13 is. Thanks. |
Quote, originally posted by MotherTucker » |
I have a US spec '07 GTI, and installed the Hella LEDs from OEMPl.us. I rewired the connectors on the lamps as specified, and used a vag-com to set the bytes properly, and got it all working.... with the exception of the side light bulb out errors. I added the 2 wires as instructed at the beginning of this thread, and it did not fix it. I was hopefull for a while that it would fix it, but it didn't. Just wanted to chime in with this. I'll keep watching here, hope to get a fix for it at some point. |
