This thread is to be a dump of working OBDeleven codes for the MQB Tiguan.
Disclaimer: My knowledge of VAG systems is very limited. The list/changes below were all aggregated from various websites/sources, and were only organized by myself. I can't provide technical help, nor can I be held responsible if you mess up your car. Basic knowledge of OBDeleven use is inferred, and it's really not that hard. I did all of these within 3 days of ever using one.
All changes are verified to work, unless otherwise noted.
Changes were tested on a NAR (Canada) 2018 Tiguan Highline w/ Driver's Assistance Package & R-Line. (SEL-P w/ R-Line equivalent for the US)
The codes below assume you have the appropriate hardware installed.
eg. Easy Entry will not work if you don't have memory seats; Adaptive Lane Tracking will not work if you don't have the front-facing camera; etc.
Below is my list of changes:
- Open/close windows with keyfob
1. Control Unit 09 (Central Electronics)
2. Security Access 31347
3. Adaptations
4. ZV Komfort
5. Funk Komfort Schliessen: Not Active -> Active
6. Funk Komfort Oefnnen: Not Active -> Active
7. Comfort Opening: Not Active -> Active
8. Comfort Opening: Not Active -> Active
- Change sunroof opening behavior with keyfob opening
1. Control Unit CA (Sunroof)
2. Adaptations
3. Komfortfunktionen
4. Target Position for Comfort Opening: Tilt or Slide
- Windows operate after turning off ignition and opening door
1. Control Unit 09
2. Adaptations
3. ZV Komfort
4. Freigabenachlauf FH bei Tueroeffnen abbrechen: Active -> Not Active
- Easy Entry
(Seats move back to furthest position when you open door after turning off ignition. They will move back to memory after you turn on ignition. Driver Profile must be enabled.)
1. Control Unit 36
2. Long Coding
3. Easy_Entry_Front: Not Active -> Active
- Puddle lights stay on when mirror is folding
1. Control Unit 42
2. Long Coding
3. Byte 01
4. Bit 5 -> Deactivated
5. Repeat above for Control Unit 52
- Auto High-Beam (HBA) always on
1. Control Unit 09
3. Adaptations
4. Fernlicht_Assistent: Active -> Not Active
*Note: HBA will turn off if light switch is moved from Auto.
- Air Recirculation Memory
1. Control Unit 08
2. Long Coding
3. Store Recirculation Air Setting for Terminal 15 Off: Service-life dependent store -> Save
- Direct Throttle Response
(Supposed to change throttle input, may be placebo but I feel it accelerates in a more linear fashion)
1. Control Unit 44
2. Adaptations
3. Switching Driving Profile: A -> B
- Adaptive Lane Tracking
1. Control Unit A5
2. Security Access 20103
3. Long Coding: Point_of_intervention late -> early (setting via menu)
- Gauge needle sweep upon startup
1. Control Unit 17
2. Long Coding
3. Byte 01
4. Bit 00 -> activated
- Digital Dash Themes
1. Control Unit 17
2. Adaptations
3. Display depiction: Choose version (changes in real time)
- Digital Dash RPM/Speedo Gauge Themes
1. Control Unit 17
2. Adaptations
3. Tube_version: Choose version (Variant_3 is GTI; Variant_4 is Golf R)
- 3D View for 360 degree camera (Area View)
1. Control Unit 6C
2. Long Coding
3. 3D_Presentation: Off -> On
- Enter address/text while driving
1. Control Unit 5F
3. Adaptations
4. Search “Locked”, change all values from Blocked to Non_Blocked
5. Long Coding
6. Go to Byte 23
7. Uncheck all items (value for Byte 23 should be 00)
*Credit for u/martiansoldier for last 3 steps. Now verified working.
- Traffic Sign Recognition
1. Control Module 5F
2. Security Access – Access Code 20103
3. Adaptations
4. Car_Functions_List_BAP_Gen2: traffic_sign_recognition_0x21 not activated -> activated
5. Car_Function_Adaptations_Gen2: menu_display_road_sign_identification not activated -> activated
6. Select menu_display_road_sign_identification (OR menu_display_traffic_sign_recognition), set to Enabled
7. Long Coding
8. Byte 24, activate Bit 6
9. Control Module A5
10. Security Access – Access Code 20103
11. Long Coding
12. Byte 16, activate Bit 4
13. Control Module 17
14. Long Coding
15. Byte 5, active bit 2
16. Control Module A5
17. Security Access – Access Code 20103
18. Adaptations
19. Road sign detection fusion mode: Road Sign Fusion -> Road Sign Detection.
20. Press and hold infotainment device power button to reboot the infotainment system.
- Starting Vibration Reduction
**In wheel slip scenarios, where wheel hop is typically induced, this tweak will stop the intervention of the braking system, allowing you to continue spinning the wheels. Assist with launching the vehicle, and stops the car from ‘bogging down’.
1. Control Module 03
2. Adaptation
3. Starting Vibration Reduction
4. Set to Starting Vibration Reduction and Torque Limitation to ‘Deactivated’
- Haldex All-Wheel-Drive Adjust Traction
**Reports indicate that changing this setting to ‘Increased Traction’ improves the handling and makes the car feel like a permanent AWD system.
1. Select AWD Control Unit
2. Adaptation
3. Acoustic Measure, Wiring Logic
4. Choose from ‘Standard, Increased Traction, Less Noise’
There are lots more floating around, that I either haven't had interest in, or haven't had the time to do and document.
- Turn off "ignition on" chime
1. Control Module 17
2. Adaptations
3. Ignition Active Message, Actuator: Driver Door -> No Display
This post will get continually updated.
3. Adaptations
4. ZV Komfort
2. Adaptations
1. Control Unit 09
2. Adaptations
3. ZV Komfort
- Easy Entry
1. Control Unit 36
2. Long Coding
1. Control Unit 42
2. Long Coding
3. Byte 01
1. Control Unit 09
3. Adaptations
1. Control Unit 08
2. Long Coding
1. Control Unit 44
2. Adaptations
1. Control Unit A5
1. Control Unit 17
2. Long Coding
3. Byte 01
1. Control Unit 17
2. Adaptations
1. Control Unit 17
2. Adaptations
1. Control Unit 6C
2. Long Coding
1. Control Unit 5F
3. Adaptations
5. Long Coding
6. Go to Byte 23
3. Adaptations
7. Long Coding
11. Long Coding
14. Long Coding
18. Adaptations
2. Adaptation
2. Adaptation
2. Adaptations
