1 - 8 of 8 Posts
I have searched for the correct answer here but have not found one that I am 100% comfortable with so I'm hoping someone here can help me out.....
Can I run a 15x6 wheel with a 40 offset without issue on my 92 Cabby?
Discussion Starter · #4 ·
Re: Offset question for a 92' Cabby (4supreme2gambino0)
Quote, originally posted by 4supreme2gambino0 »
definetly, stock is 35....40 shouldnt cause any problems unless ur slammed
anyone second this?
The car is not slammed, can anyone else confirm that 40 offset will be ok
Discussion Starter · #6 ·
Re: Offset question for a 92' Cabby (briano1234)
Thanks, I'm aware of what the stock offset is. I'm trying to see if anyone has run a 15x6 with a 40 offset on a 92 or knows if this will work.
Banned
Re: Offset question for a 92' Cabby (JEB23)
In most cases you'll be fine. Depending on the wheel design, the suspension springs you have, and the tire sidewall design you may get a bit close to the springs. On my ET40 wheels with 205 Eagle F1s I have to run 5mm spacers to clear the springs. Falken 512s are fine.
Discussion Starter · #8 ·
Re: Offset question for a 92' Cabby (ZombiePatrol)
Thanks for the input....I figure I will have to likely have to run spacers to get by.
1 - 8 of 8 Posts
