1 - 18 of 18 Posts
Re: Oh man, look at this motor....................... (MaestroG60)
And what's keeping that serpentine belt under tension
I can see the timing belt tensioner being used but the original arm and pulley must have had some sort of spring fitted to it to act like the original damper unit.
Still top setup
[Modified by Markie, 6:07 PM 4-8-2002]
Re: Oh man, look at this motor....................... (OttawaG60)
Whats up guys, thanks for the comments and what not....especially you Jay (DubG60) you clown..but yah its a full 2.0 liter crossflow setup..specs as follows
2.0 ABA crossflow stock block 28K miles
Crossflow Head ported, polished, 3 angle valve job, brand new everything.
Brospeed header
Custom Intake manifold
278 Web Cam
Stock Charger 53mm pulley
UR crank pulley
Dual Intakes for Charger
Spearco Front mount intercooler
Greddy Type S BOV
2.5 polished stainless pipes
500cc injectors
Autronic SMC stand alone engine management
stupid little stuff too, but can't really think about it right now since I'm tired as all hell haha...oh and the engine is not finished yet thats why the belts aren't tight or anything...Manifold was made by my Tuner...$500 bucks for any rpm range you want email me for details if there is serious interest. I've the guy that posted his pic with the 270 hp engine is serious then I should be making a hell of a lot more than the 250 I was thinking off ...what do you guys think? let me know
thanks,
Re: Oh man, look at this motor....................... (corrado2z2)
quote:[HR][/HR]A 53mm pulley?!! Won't you be over spinning the charger?[HR][/HR]​
not really because he is using the unorthadox racing underdrive crank pulley wich i believe is 114mm instead of 133mm wich means the charger will need a small pulley in order to get the right amount of boost
so a 53 mm pulley is more like a 72mm pulley
[Modified by joeZX6, 12:23 PM 4-9-2002]
Re: Oh man, look at this motor....................... (joeZX6)
http://****************.com/smile/emthup.gif Nice work JoeZX6 your the only one that caught on to that one..haha theres a 11mm difference between the UR pulley and stock so I'll be running like a 66-67mm charger pulley..well thats what it will seem like..so hopefully the charger will be running anywhere between 13-14 psi.
quote:[HR][/HR]You may want to check the fit of that alt, I have a feeling it may hit the subframe and/or the rad.[HR][/HR]​
Or this could be the answer to your alternator problems!!!
1 - 18 of 18 Posts
