what do you guys use, if anything, to clean out fuel injectors etc. and how much do you use?
G GnarKill · Registered Joined Aug 3, 2005 · 146 Posts Discussion Starter · #1 · Sep 11, 2005 Only show this user what do you guys use, if anything, to clean out fuel injectors etc. and how much do you use?
J JettaRed · Registered Joined Aug 14, 2000 · 8,403 Posts #2 · Sep 11, 2005 Only show this user Re: oil and fuel additives- any recommendations? (GnarKill) Fuel additives yes; oil additives NO! Fuel additives: Chevron Techron, Gumout
L LA Wolfsburg · Registered Joined May 8, 2002 · 5,998 Posts #3 · Sep 11, 2005 Only show this user Re: oil and fuel additives- any recommendations? (JettaRed) ive been using lucas upper cylinder lube.
G GnarKill · Registered Joined Aug 3, 2005 · 146 Posts Discussion Starter · #4 · Sep 11, 2005 Only show this user Re: oil and fuel additives- any recommendations? (LA Wolfsburg) ive heard good things about lucasoil... how/when do you add it?
Q QuickK03Crap · Banned Joined Oct 5, 2004 · 10,373 Posts #5 · Sep 11, 2005 Only show this user Re: oil and fuel additives- any recommendations? (LA Wolfsburg) Quote, originally posted by LA Wolfsburg »ive been using lucas upper cylinder lube. Same here.
L LA Wolfsburg · Registered Joined May 8, 2002 · 5,998 Posts #6 · Sep 12, 2005 Only show this user Re: oil and fuel additives- any recommendations? (GnarKill) i run about 4 ounces on every tank. you can get a big 32 oz bottle for 8 bucks at autozone.
