What up everyone!
I'm in a little bit of a bind. I need to fix a 92 jetta 8v.
It has oil residue in the coolant over flow tank. I am not sure if it is also in the oil pan and cannot check because the car is 2 hours from my location.
Basically I am wondering if I should be replacing the head gasket or the oil cooler and O ring?
I have all parts on order even the oil cooler but of course only want to replace what is necessary.
Also, the car is hard starting the first time of the day. Should the blue coolant temp sensor be replaced?
