Anyone have oil leak at the bottom of the upper timing chain cover ? Was checking for engine Bay bearing noise, maybe alternator or serpentine belt tensionner and discovered oil leak. So I have 2 problems to fix now. Tiguan 2018 with only 35000 km.
Your sounds like plastis belt tensioner failing but know the timing chain tensioner is a know problem that leak down causing timing chain failure is so bent head valve will follow it a interference engine Humm if under warranty see tech bulletin vw :^) that major asap will cost way more if not done have then replace two balance shafts too the lock up over time small plastic oil micro screen get block they have up dated replacments parts that solve them problems 😉 catch it early save a while bunch monet, time, and down time with out motor lock up lol :^).Dealer replaced timing chain upper cover under warranty but they are unable to find bearing noise after 3 days. Here is my sound.
