Re: oil leaks out of my oil cap (eastcoastdubs)
The blow by gases should be handled by the PCV valve. It is much easier for the gases to go thru the PCV valve than the oil cap so I strongly don't think that blow by is the problem. I would check out the seal on the bottom of the cap and make sure the cap is seating properly. Your valve cover is not bent up around there is it?
