1 - 3 of 3 Posts
I'm getting a beep and flickering oil light when slowing to a stop from highway speeds. The oil is full (maybe slightly over, but the problem started 2K after the last change/fill). I'm hoping it's just a faulty sensor, but is this a "Known Problem" of some sort? TIA
Re: Oil Light in '99 Passat 1.8T (VW Newbie1)
it shouldnt be overfilled...that could be your problem...not a HUGE issue...but since your over 2K miles sicne your last change...just get it changed
The sending unit could be bad, or oil that is too thin was put in.
Overfilling the oil can cause it to foam up, causing problems.
Over filling can blow seals out, get into and ruin the catalytic converters, and is a bad idea.
Oil pressure problems are likely very rare.
A mechanical problem would have the motor knocking badly, although its possible to have a stuck bypass valve in the pump I suppose.
You can measure the oil pressure with a gauge, not sure how hard that is on the 1.8t, you would screw a gauge in place of the oil
pressure switch that activates the alarm.
Since you might replace the switch anyway, checking the actual
pressure would be a good idea, and should be easy to do.
If the pressure IS low, could be a pump problem (stuck open bypass).
Not sure if you can get at the bypass valve without a lot of effort.
Some engines have easy ways to get at it.
Brett
2003 GLX
1 - 3 of 3 Posts
