bored in class so i can't go look...help me out for later tonight
w/ a turbo...you mount the oil feed off the oil filter houseing...and the oil return on the oil pan correct? so what do you do with the 2 lines that used to feed the supercharger? if i remember correctly the return line is on the front of the block...and the oil feed is???? the side of the head maybe? what do you do with those 2 lines? pull off the line and slap a bolt in there? the ATP directions dont help a whole lot. why do they say to remove the axle....just to give you more room to work under the car?
