I'm replacing my oil pan gasket and needed to know if I needed to use the grey permatex silicone sealant along with it. Or do I just clean both surfaces and bolt together?
BTW would violently breaking my front mount cause my main seal or rear seal to get disturbed or damaged in any way so that it leaked? I really can't tell where all the oil is leaking from. I'm just changing the obvious gasket first, because anything above the pan looks basically dry compared to the pan. There are also drip marks on the ground in front of the pan as well as between the engine and tranny. Thanks for any insight.
