You'll need an M10x1 - 1/8" NPT adaptor. You have two choices for location. Your first choice is the blank plug on the top of the oil filter flange. Using the adaptor I mentioned above, you remove the hex plug and install your sender. You may have to unbolt the bracket which holds the engine speed sensor.
Your other option is to use a relocation kit. Our 1/8" NPT relocation kit will allow you to install the Autometer sender and the OEM sender in the OEM location. The adaptor method will cost you $6, where as the relo kit will cost you $24. Your call, based on how you feel about working with the blank plug or the OEM sender. http://www.42draftdesigns.com/product/42901.htm http://www.42draftdesigns.com/product/sw/42008.htm
1 - 2 of 2 Posts
