Oil Pump in 84 Quantum TD
505 Views 7 Replies 5 Participants Last post by  Aw614
Hi. I just joined the forum, as I just bought the car. Car is in very good shape, but has 257K on it. I am a little concerned because the oil light is flashing occationally at idle. This only happens after the car is up to temp, and then only after it is driven for a while. I fixed it temporarily by raising the idle a bit, I am thinking it may need a new oil pump.. Has anyone done this? I am very mechanically inclined, but I don't yet have the service manual. Any help or suggestions would be greatly appreciated. Thanks.
Ken
1 - 8 of 8 Posts
Re: Oil Pump in 84 Quantum TD (84QuantumTD)
The thing that should be done first is replacing the engine oil. Fill it with 10w30 and make sure it is rated for turbo diesel engines.
Re: Oil Pump in 84 Quantum TD (PerL)
Hi... That was the first thing I did... I got some oil, and a filter at AutoZone.. It was made by Shell "Rotella" I think was the name on it, and it was heavier that 10W 30 . It said it was made for diesel's and listed Cummins, Detroit Diesel, and Catapiller.. on the back....
I looked at my regular oil for my Miata (Mobil 1 Synthetic) but it did not list the 2 letter tag for diesel on the label. Do you have a recomended oil?
I did notice one other thing today... I think the car may be running a bit on the hot side. I tried running the main fan (hot wired it) and this did not help. I am going to try to change the therostat tomorow, and see if I can get it to run a little cooler. I hope it is not the oil pump, as this will require removing the engine to replace. Thanks for your help..
Ken
See less See more
Ok, you think you're going too hot. It would be best to make sure if you are! If you are, try to replace the thermostat (go to the dealer to get teh best ones, same with oil filter). If the engine is running too hot, the oil will be too thin and the light might flicker. I dont think you need to remove the engine to replace the oil pan, but I'm not sure. My sister had an '87 Passat (same as Quantum) so I know the cars a bit. You need to drop the oil pan, but I dont know the exact oil pump replacement procedure so... It's the same as for a regular gas engine though.
If the engine is worn, it might not help with a new pump. The main bearings may have too big gaps, which means that there wont be any back pressure for the oil pump, this will make the oil pressure drop. I've experienced this on an aircooled VW.
See less See more
HI... Thanks for the info. I am going to change the thermostat. I bought one today. I got a 180.. stock is 195. I figured try one a little cooler it might help too. They make a 160, but it would have to be ordered.
If it's the bearings..well I guess I will just have to drive it till it blows up. Car runs great... and the light only comes on at idle...and soemtimes not even then... I have raised the idle a little, and that helped some. I was also thinking it could be a bad oil sender... the sender might just THINK the oil presure is too low. The engine does not clatter or tick or anything when the light goes on... I might try to hook up an actual oil pressure gauge to make sure.
It is a daily beater and I have put almost 1000 miles on it this week mostly city driving. So if it was going to blow up. I think it would have already. I got 34MPG this tank
Not bad for a 18 year old car with 257K on it.
Thanks again for you help.
See less See more
It will probably go for years and years with low pressure at idle. This is fairly normal behaviour for older high mileage cars.
It is more important that oil pressure does come up as the engine is revved.
Maybe it is time to get an oil pressure guage.
Re: Oil Pump in 84 Quantum TD (christi)
someone else with a old Quantum. Mine is the 5 banger though.
My Jeep Grand Wagoneer only carries about 10lbs at idle. That is very common among the AMC V-8's. and it is more than enough for a gas motor at idle..
Re: Oil Pump in 84 Quantum TD (tuckers85vw)
I have an 87 SW non Syncro bought new in 87. My parents bought it.
My fuel gauge is dead on it and its on the bottom and doesn't move any ideas
1 - 8 of 8 Posts
