Oil squirters
731 Views 3 Replies 3 Participants Last post by  Damien
Guys,
How do you bore the block to 83mm with those oil squirters. It looks like they would be in the way. Obviously, I know it's possible to bore and keep the squirters, but how is it done?
tx,
Gary
1 - 4 of 4 Posts
Re: Oil squirters (Kokino)
You remove them
I believe it's a torx or triplesquare bit
See less See more
Re: Oil squirters (smoked_g60)
quote:[HR][/HR]You remove them
I believe it's a torx or triplesquare bit[HR][/HR]​
Can they be reinstalled after boring/honing, I really don't want to get rid of them.
Tx,
Gary
See less See more
quote:[HR][/HR]Can they be reinstalled after boring/honing, I really don't want to get rid of them.[HR][/HR]​
yes, they can and should reinstalled after boring the block. you may want to soak them in alcohol or cleaner to rid them of any oil build-up inside. be careful removing them as they bend (and break) rather easily as they are brass. make sure to have the oil passages in the block cleaned as well.
1 - 4 of 4 Posts
