1 - 11 of 11 Posts
I had a leakage in the oil temp switch so I removed it and plugged the hole with a bolt.
But when I drive the oil warning light comes on + sound from the buzzer, is this ok to drive with for a couple of days??
What about when you 16v turbo guys uses this for the oil feed line, will the oil light/buzzer go on??
(sorry for my bad english, hope you understand)
This is the oil temp switch I'm talking about:
Re: Oil temp switch (Mk2Vr5)
same thing happened to me...just go an buy a new one.. it cost me only 20 bucks...saves you the headache...
Re: Oil temp switch (dubidoobs)
Quote, originally posted by dubidoobs »
Yeah I'm going to buy a new tomorrow, but it is safe to drive without it until I get a new one (when the oil light/buzzer is on) ??
Just have to be sure
dunno if it's safe or not, but the whole point of that switch is to monitor that ur engine has enuff pressure. oh, btw, the one i got for my car doesn't look like that stock one...the stock looks like a nut with a contact...i guess that was the style in the 80's, but the one the parts shop gave me is like 2x bigger, but it works...
Quote, originally posted by Mk2Vr5 »
Dunno why it wouldn't be safe to drive it since it's only warning you of a low oil pressure condition that doesn't exist. Just ground the wire out and you should silence the warning.
A while back when I suspected my oil pump was going, I hooked in a cheapo mehcanical oil pressure gauge at the same location as that switch. Not in place of the switch, but on a T. The tubing for the guage changed the pressure just enough for the switch that the warning light kept coming on. I grounded it out until I removed the guage.
stef
Discussion Starter · #6 ·
Re: Oil temp switch (vwgti1986)
Quote, originally posted by vwgti1986 »
stef
I was thinking that too, but got a little unsure when the oil light/buzzer whent on
just had to be sure
Thanks
if you're gonna drive w/out it, just make sure you got oil...nothing worse that running a motor w/out it's lifeblood!
Banned
$20!? Where did you buy that? Rapid?
You can get both high and low oil pressure switches from the dealer for about $15 at retail prices.
Re: Oil temp switch (Phobia16V)
Quote, originally posted by Phobia16V »
Yup, I got mine for a few bucks.
1 - 11 of 11 Posts
