Oil warning light
772 Views 4 Replies 5 Participants Last post by  vr6willeatyou
I have noticed this problem several times especially when it is about time to change the oil. The oil warning light will come on when I make a really hard turn and then it will go off. I don't understand why it is dong this. The car is not leaking oil anywhere (at least I haven't noticed on my garage floor) and I know that I put enough oil in when I change the oil. I use synthetic 5W 40 but I used to use regular 20W 50 because of my mileage (over 100K). But it didn't matter because it use to do it with regular oil. Anybody else have this problem?
Jerry
1 - 5 of 5 Posts
Re: Oil warning light (Jwchan)
Check your oil level regularly (every fill-up or every other fill-up). Your oil level is probably low, setting off your oil pressure sensor, because the oil is sloshing around it. VR6's burn oil more than they leak it.
See less See more
Re: Oil warning light (vr6Cop)
sounds like low oil levels check it out.
Re: Oil warning light (kingofA2`s)
Same deal, happens when I am low on oil and make a sharp turn; add oil, no more oil light!
Re: Oil warning light (SparkGLXVR6)
Always check your levels between changes. If I know I will be driving more than an hour I usually check it to make sure!
See less See more
1 - 5 of 5 Posts
